Onderwerp: 2200 pk straatlegale dragracer
2200 pk straatlegale dragracer 06 feb 2010 15:57 #9492
CAR
1972 Vauxhall VX4/90 FD. Originally came with a 104hp 2000cc 4 cylinder engine.
ENGINE
572CI Chevrolet
Dart big M block
Lunati pro series 4340 forged crank
Oliver billet steel rods
Diamond turbo pistons
Speed pro "Hellfire" rings
Aviaid 4 stage dry sump pump
Modified Aviaid oil pan
Altiss engineering custom oil pump drive,oil tank and breather can
Jesel cam belt drive
Don Bailey designed Comp Cams custom turbo roller cam
Comp Cams H/D roller lifters
Manton 210deg 7/16" ex pushrods,Comp cams 7/16" intake
Cometic multi layer steel head gaskets
ARP heads studs
Dart Pro1 355 CNC heads with Ferrea stainless intake and super alloy exhaust valves modified by RFD dvelopments
Edelbrock 454R intake manifold modified by Altiss for 2 x 1500cc Ford motorsport injectors per cylinder
Manley valve springs
T+D 1.75 shaft rockers
Ali rocker covers modded by Altiss
2 x Holset 88mm custom hybrid turbos spec'd by Holset with inconel exhaust wheels
Custom 321 stainless headers by Altiss c/w2 x Turbosmart pro wastegates
Burns 321 stainless merge collecters and Custom 321 stainless 4.5" exhaust system
Turbonetics "Godzilla" BOV,Billet 2200cfm throttle body
Custom throttle body hat CNC'd by Taylor machine and finished by Altiss
2 x ARE cooling 12"x7"x 13""" Air to water cores,c/w 8 gallon water tank.Tanks fabricated by Altiss
all pipes and brackets custom made by Altiss
IGNITION AND FUEL
Electromotive TEC3R ECU inc Electromotive DIS ignition coils
Electromotive 60-2 crank trigger wheel
PCS D200 datalogger(for extra logging)all tuned by Steve Sczepanski of Mechanical power systems of Canada
3 x Aeromotive Eliminator fuel pumps(1100hp each) c/w fuel pump controller for road use on 1st pump and Turbosmart fuel regulator.
Custom 10 gallon fuel tank by Altiss
Thermo -Tec and DEI heat management products throughout the car
Goodridge and Speedflow hoses and ends throughout
Runs on Shell V Power and Powerpour additive
2008 running on VPMS 109 and Q16
TRANSMISSION AND REAR AXLE
Penn Autos/Andy Frost race trans Dedenbear cased 2speed transbrake Powerglide auto(2500hp capable) NealChance 10.5" pro-mod bolt together converter.
B+M pro stick shifter
WRE braced Ford 9" axle with 35spline Moser shafts
Strange nodular iron case,aluminium pinion support,C/M spool and 3.25 to1 Motive gears
4.5" x 50 row air to air cooler c/w Laminova water to air cooler in series.
Pacet 700cfm fan on cooler
2008 Wheelie bars are in use for the WSR2
SUSPENSION
Gazmatic gas/fluid double adjustable front struts with Hyperco springs
Robinson race cars front arms
Strange double adjustable rear shocks with Hyperco springs
Webster race engineering 4 link,sliding "A" frame locator and rear anti roll bar
BRAKES
Hi-Spec motorsport Custom 4 Pot Calipers and 300mm vented disks c/w race brake pads(front)
Hi-spec billet handbrake calipers and Hi spec motorsport 260mm discs and custom bells c/w race brake pads(rear)
Mopar 1.125" master cylinder
Stroud parachute(for racing)
WHEELS AND TYRES
6" X 15" Centreline Convo pros c/w Goodyear 185 x 55 x 15 v rated tyres(front)
12" x 15" Centreline Convo pro custom bead lock wheels c/w 315 Mickey Thompson drag radials
2008 15" x 15" American racing double beadlock wheels with 33" x 18.5" MT et streets.
BODYWORK
Vauxhall VX4/90 steel body with a DRE fibreglass front end,bumpers, boot,bonnet and scoop
Aluminium pro stock style rear spoiler
Camaro NASCAR front spoiler
custom air intakes(for turbos)
converted to 2 door
Mini chilli red paint and prep by West Midlands accident repair
graphics by Curbishley Automotive
Andy Frost built steel SFI 25.4 tubular chassis
SFI tech'd to 7.50 in the 1/4 mile
Weight 3400lbs at the startline(with wheelie bars 3430lbs)
INTERIOR
All Alloy panelling by Robinson race cars and anodised black
Custom alloy seats covered in leather by Aldridge trimming
Headlining and carpets bound by Aldridge Trimming
custom switch panel and street wiring by Ken Britten
ECU wiring by Steve Sczepanski
rest of the wiring by Andy Frost
Autometer gauges
SPA speedo
2 x Innovative AFR gauges
AMS 1000 boost controller
ICE
The glorious sound of a twin turbo V8 engine.........
PERFORMANCE
0-60mph =1sec
0-153mph = 4.8secs
Standing 1/4 = 7.6secs on pump gas and 315 MT drag radials
standing 1/4 = 7.41and 197.6mph on ET streets and VP Q16 so far.......
top speed = 223mph ,and no bodywork came off.This was done at Bruntingthorpe Sept 2008.That speed attained in a slow 19secs due to excessive wheelspin and coming out of the throttle(which was 1/3 down max!!.
Street Eliminator speed record holder 190.4mph so far....
World pump gas ET and speed record holder on MT 315 radials.7.67 @190.4mph so far.....
2 x UK Castrol challenge winner 2006/2007
King of Europe winner 2009. King of Europe speed and ET record holder 7.81 @ 188mph.
www.redvictor1racing.co.uk/
Re: 2200 pk straatlegale dragracer 06 feb 2010 16:29 #9493
ik heb gehoord dat de eigenaar met iets nieuws bezig is...
kan me alleen niet herinneren wat het is :(
Re: 2200 pk straatlegale dragracer 06 feb 2010 17:51 #9494
dus je hebt het gevonden leo, leuk stukje,goed bezig.
zou je vader maar wezen die je met dat ding van school op haalt.....gaaf.
Time to create page: 0.227 seconds
