Onderwerp: BMW M3 Turbo
BMW M3 Turbo 03 feb 2010 10:10 #9406
ENGINE MODIFICATIONS
EXTERNALS
S50US 3.0 liter conversion
Garret GT35R dual Ball-Bearing Turbo
ACTIVE AUTOWERKE Turbo Exhaust Manifold
ACTIVE AUTOWERKE Specially prepared ECU
ACTIVE AUTOWERKE Blow-Off Valve
ACTIVE AUTOWERKE Turbo HFM (3.5 HFM)
ACTIVE AUTOWERKE Fuel Pump system
1200 HP Front Mount Intercooler
TIAL 38mm External Wastegate
RC 550cc Injectors
Big Bore Throttle Body
CODEPRO Motor Mount Brace
Aluminum 4 Inch Intake Piping
Aluminum 3" charged pipes
ROUGE Engineering Power Pulleys
Ignition Solutions Plasma Coils
INTERNALS
M50 Cylinder Head
S50US Valve, Springs, Retainers and Keepers
S50US Camshafts
ARP Head Studs
ROSS Forged Low Compression pistons
Total Seal Gapless Piston Rings
Total Seal Wrist Pins
S50US Connecting Rods
S50US Crankshaft
S50US Block with slight over bore
COOLING EXHAUST SYTEM
SPEARCO Prototype Aluminum Radiator
SPAL 1200CFM Electric Fan
80c Thermostat
Aluminum Thermostat Housing
80c / 88c Fan Switch
Victory Product Designs Oil Cooler Kit
180 degree Thermostat for Oil Cooler
CODEPRO 3" Stainless steel Downpipe
CODEPRO 38mm Stainless steel wastegate piping
JP Performance Twin Dual DTM Stainless steel exhaust system
Dual HI-Flow Catalytic Converters
(4) Magnaflow Resonators
DRIVETRAIN
SUSPENSION
Getrag 5 Speed Manual Transmission conversion
3.15 Limited Slip Differential Conversion
CLUTCH MASTERS Stage 4 4-puck race Clutch Disk
CLUTCH MASTERS Stage 4 Pressure Plate
Aluminum Lightweight Flywheel
ROUGE Engineering Short Shift Kit
ROUGE Engineering Clutch Stop
ACTIVE AUTOWERKE Diff Brace
H/R Coil Over system (front)
H/R Adjustable rear suspension
H/R rear Tender Springs & Retainers
BMW Motorsport X-Brace
ROUGE Engineering Strut Brace
ROUGE Engineering Transmission Mounts
Modified Pass side Engine Mount
Racing Dynamics Adj Front Sway Bar
Racing Dynamics Adj Rear Sway Bar
GC Rear Shock Mounts
WHEELS / TIRES
BRAKES
BBS Motorsport 3-piece Modular Racing Wheel
Forged Aluminum centers with Spun Aluminum outers
Yokohama AVS Super Sport Tires
BREMBO Big Brake 4 piston Calipers
BREMBO Cross Drilled Rotors
Stainless Steel Braided lines
EBC Brake Pads (red)
ENGINE SPECS
Engine designation: S50US
Configuration: Inline 6
Capacity: 3.0L
Valvetrain: DOHC, 4 Valves/Cyl w/ VANOS variable timing
Displacement: 2990cc
Bore: 87 mm / 3.39 in.
Stroke: 85.6 mm / 3.37 in.
Max RPM: 7500 rpm
Induction Type: GT35R 1.06 A/R
Boost: 13psi street / 20psi track
Static compression: 8.5:1
Camshaft specs: Stock
Exhaust: JP Performance exhaust system
Intake: Custom 4"
Engine Management: AA software tuned for 91 octane
Boost control: BLITZ SBC-IColor / TIAL 38mm Wastegate
Re: BMW M3 Turbo 03 feb 2010 10:16 #9407
Wat zal die bruut 'lopen' ! :S
Re: BMW M3 Turbo 03 feb 2010 12:34 #9409
Meer info over deze auto; www.jonsibal.com/home.html
Re: BMW M3 Turbo 04 feb 2010 07:39 #9437
wat een gaaf kombi instrument!
en als dit:"Total Seal Gapless Piston Rings" is wat ik denk dat het is, heb ik het nog nooit gezien.
Re: BMW M3 Turbo 04 feb 2010 07:40 #9438
Time to create page: 0.221 seconds
