Onderwerp: Mazda RX-7 met Cosworth motor
Mazda RX-7 met Cosworth motor 12 nov 2009 12:59 #6132
Power: 440BHP & 430Lb Ft (BP Ultimate 102 Fuel)
Target weight 1090Kg (Dry)
Engine:
Cosworth YB. Stronger 4x4 200block. Special spec head porting. Forged pistons. Spec custom Re-profiled cams. Arp studded head Custom spec'd Carrillo Rods. New bearings, piston rings. 440cc injectors. Steel head gasket. Oil breather tank. Custom inlet manifold. Custom Exhaust manifold. Motorsport plenium. baffled sump & modified pickup. Uprated
engine bearing set . Motorsport oil pump. Engine Castrol Edge 10W40 Sport. Turbo / Intercooler: Garrett by Honeywell GT30 Ball bearing Turbo. uprated actuator. V MOUNT !!! GTC 600x300x100 GT spec Intercooler (capable of handling up to 800BHP). intercooler pipe work. Custom tubular exhaust manifold. 60mm racing waste gate. Externally venting screamer pipe. GTC custom exhaust system with side exit. custom radiator & pressurized water system. GTC19 row oil cooler kit mounted for maximum air flow cooling properties. Reallocation plate and oil lines. Electronics /Fuelling: ecu. Updated map sensor, twin fuel pump. Boost pressure. gauge. Volt gauge. Auto Gauge 5 with Tacho meter & shift light. Oil pressure. Oil Temp. Water Temp. Exhaust temp. Hybrid boost controller. racing fuel regulator. fuel rail. fuel feed lines. fuel filters. Twin Bosch 044 fuel pumps. custom low mounted fuel tank. Swirl pot. Motorsport fuel cell. Race battery with Motorsport battery holder. Custom full wiring loom.
Exterior:
Full Kazama Auto Wide body kit. To include: front bumper, Rear bumper, Side skirts, front fenders, rear fenders. Rear FRP light weight Hatch. RE headlamp conversion. Aero catch bonnet catches front and rear. GTC Lexan windows with slide doors. HKS Kansai pulling hook modified. Single wiper conversion.
Interior:
Cobra Evolution S FIA Seat & Harnesses & Cobra side mount. Sparco GT spec steering wheel. Hydraulic hand brake. Switches: Kill switch, Fuel pump, fans, lights, starter button. Modified peddle box. Modified steering rack. Custom fabricated rear boot floor & infill panels, front floor panels . dashboard infill panels.
Drive Train / Braking:
Cossie gear box and running gear. Gear box Castrol transmission fluid. Twin plate Clutch. Mazda RX7 callipers with uprated discs and Endless CCX pads. Stainless steel brake lines. Twin master cylinders. drift gear stick. Brake Fluid Castrol. LSD. Diff Oil: Castrol.
Chassis / Wheels:
Special made just for us Weds Sports 105N’s 18x8.5 front and 18x9.5 rear in Floro yellow. With light weight racing wheel nuts. Sitting pretty on excellent Cooper Tires Zeons front 225/40ZR18 Rear 245/40ZR18
Cage:
full weld in load bearing roll cage . cage to body stiffener plates. Shell sand blasted and mass weight saving and strengthening process. Full spot weld for strengthening. Cages comes though to the bulk head.
Interior totally stripped. FIA life line electrical fire extinguisher system, air con removed, hydraulic hand brake, racing brake bias valve, boss kit, f1 style dry break fuel fitting entry with fuel breather
Re: Mazda RX-7 met Cosworth motor 12 nov 2009 15:02 #6138
bij mij doen de foto's het niet.... :(
Re: Mazda RX-7 met Cosworth motor 12 nov 2009 15:36 #6139
Krijg je kruisjes te zien?
Bij mij zie ik de foto's wel namelijk.
Re: Mazda RX-7 met Cosworth motor 12 nov 2009 17:09 #6143
nee, hij laadt wel de ruimte voor de foto's maar blijft blank (firefox 3.5)
Re: Mazda RX-7 met Cosworth motor 12 nov 2009 18:00 #6149
Dan kan je deze link eens proberen; www.gtc-r.com/ en dan kijken bij demo cars
Time to create page: 0.221 seconds
