Onderwerp: Evo 3
Evo 3 28 okt 2009 10:08 #5342
1995 MITSUBISHI LANCER EVOLUTION III - Specifications
Engine: Mitsubishi 4G63 2.2-litre DOHC 16V inline-4, decked block, bores honed, balance shafts removed, modified oil pump, nitrided/polished 4G68D crankshaft, ACL race bearings, ARP L19 rod bolts, Saenz forged competition rods, Wiseco forged pistons, Lynn Rodgers balanced bottom end, Ralliart head gasket, ported/polished head, ARP 12mm head stud kit, heavy-duty valve guides/retainers, Kelford heavy-duty valve springs, Kelford 280-degree stage III camshafts, HKS adjustable cam gears/cam belt, Simota air filter, custom alloy intake/intercooler piping, MSE-balanced Garrett GT3582R turbo, custom PMW steam pipe exhaust manifold, Tial 38mm external wastegate, custom 600x300x76mm PMW intercooler, 500hp in-tank fuel pump, 800hp Bosch 044 external fuel pump/filter, -6 fuel lines, custom fuel cell, Rochester 1000cc injectors, HKS fuel rail, Turbosmart FPR, Top Gear Autotech 3-inch exhaust, custom oil breather bottle, custom PMW radiator, Craig & Davis fan, Autronic SMC engine management system, Turbosmart e-Boost, Top Gun heavy duty leads, semi de-loomed engine bay, Ralliart engine mounts
Driveline: Modified factory 5-speed gearbox, carbotic paddle clutch, heavy-duty pressure place, rear LSD, 4-spider centre diff, Ralliart plate front LSD, Nolathane bush conversion, Evo IV RS steering rack
Suspension: Drummond Motorsport 3-way coil-overs, Eibach springs, K-Sport 12mm adjustable camber plates, Ralliart heavy duty bushes, Cusco H-pattern subframe brace, seam welded front/rear strut towers, modified front chassis rail and North/South crossmember
Brakes: ABS removed, modified master cylinder, Wilwood billet 4-pot callipers, 2-piece slotted rotors – front, factory callipers – rear, HEL braided brake lines, Carbotech XP 10 brake pads, Motul brake fluid
Wheels/Tyres: 17x7-inch Impul RS wheels/17x7-inch ANZ RGII wheels, 225/45R17 Dunlop Direzza 03G semi-slicks
Exterior: Factory Evo III bodykit, yellow respray, RS front doors, lightened RS rear doors, custom flared guards, 3mm alloy sump guard
Interior: Momo bucket seats, Willans 6-point harnesses, 8-point MSNZ-approved roll cage, Defi engine monitoring system – fuel pressure, water, oil temp, exhaust temp, MoTeC shift light, Monit rally meter, Greytronics intercom
Performance: Dyno Power – 350kW-at-the-wheels capable depending on boost settings, Pukekohe – 1:06.58, Taupo Track 2 – 1:18.35
Re:Evo 3 28 okt 2009 11:10 #5348
mooi opgebouwd !!
Re:Evo 3 28 okt 2009 11:34 #5350
Zeker een mooie machine!
Re:Evo 3 28 okt 2009 11:39 #5351
met reserve wiel, wat een luxe.
ziet er mooi uit onder de kap
Re:Evo 3 28 okt 2009 12:49 #5365
... én dashboard én deurpanelen én matten én .....
Hier is dus niet op de laatste kilo gekeken.
Re:Evo 3 28 okt 2009 13:00 #5367
Een Evo 3 is al een stuk lichter natuurlijk, en als je deze auto dagelijks gebruikt kan ik mij er iets bij voorstellen.
Re:Evo 3 28 okt 2009 18:11 #5378
mietje!!
Re:Evo 3 28 okt 2009 19:14 #5380
Komt best wel van zijn plek met die kilo's, denk ik.
Re:Evo 3 28 okt 2009 20:19 #5389
Mijn auto is lichter dan die van jou! ;)
mietje!!
Time to create page: 0.525 seconds
