Onderwerp: Mitsubishi Lancer Evo 1
Mitsubishi Lancer Evo 1 09 okt 2009 20:15 #4428
1993 Mitsubishi Lancer EVO I - Specifications
Engine: Mitsubishi 4G63T 2.3-litre DOHC 16V, stroker crank, Crower forged rods, JE forged pistons, Pro Seal rings, removed balance shafts, ARP main studs, ARP rod bolts, ported/polished head, HKS 272-degree cams, Ferrea oversized valves, bronze exhaust valve guides, Crower valve springs, Crower titanium retainers, HKS adjustable cam gears, ARP head studs, HKS timing belt, Comp stainless steel headgasket, stainless 4-inch intake pipe, HKS Super Power Flow air filter, custom alloy intercooler piping, custom stainless steel exhaust manifold, Garrett GT3540 turbocharger, GReddy blow-off valve, 600x300x76mm intercooler, Tial 46mm external wastegate, custom boot-mounted fuel cell, 2x Bosch Motorsport 975 fuel pumps, -8 braided fuel lines, Aeromotive fuel pressure regulator, Blitz 1000cc injectors, NGK leads, Denso Iridium plugs, custom alloy radiator, 3-inch stainless HKS exhaust system, Earl’s oil cooler, Autronic engine management system, Blitz SBC-DC boost controller, de-loomed engine bay, custom engine wiring, custom alloy oil catch can, custom radiator overflow, HKS oil filler cap, alloy crank pulley
Driveline: Factory Evo I 5-speed gearbox, HKS flywheel, HKS twin-plate clutch, Cusco front/rear limited slip differentials
Suspension/Brakes: Tein adjustable coil-over shock/springs, alloy strut brace, factory 4-pot callipers, slotted discs, braided lines
Wheels/Tyres: 17-inch Buddy Club P1 alloys, Bridgestone Potenza 215/40R17 tyres
Exterior: Shaved fuel filler, shaved aerial, custom Dr Bob purple paint, smoked tail lights, smoked side markers
Interior: Stripped/painted, NZDRA-spec roll cage, Recaro SR seat, Momo steering wheel, Auto Meter water temp gauge, Auto Meter oil temp gauge, Omori oil pressure gauge, Auto Meter 5-inch tacho
Performance: Dyno Power – 400+kW @ wheels
Re:Mitsubishi Lancer Evo 1 09 okt 2009 20:23 #4429
heftig ding!
veul mooier dan de de Evo XIVCVMVXXCVIIII van nu...
Re:Mitsubishi Lancer Evo 1 09 okt 2009 20:33 #4430
Evo 10 bedoel je? :D
Laast bewerkt: 09 okt 2009 20:33 Door Leander.
Re:Mitsubishi Lancer Evo 1 09 okt 2009 20:34 #4431
Evo 10 bedoel je?c:D
zijn we nog niet bij de 193482386234893699823569214ste dan ? :P
Re:Mitsubishi Lancer Evo 1 11 okt 2009 12:44 #4459
ZO! Deze Evo hebben ze goed onder handen genomen!!
De meeste Evo's vind ik standaard al wel mooi maar de laatst (Evo 10) is echt "Plastic Fantastic" zooi.
Mooie screamer pipe heeft deze!! Zal vast wel boven het DB limiet van NL wet uit komen :P .
Re:Mitsubishi Lancer Evo 1 11 okt 2009 16:37 #4461
dit vind ik mooi spul zo'n evo
kwam vrijdag een mooie VI tegen met groene platen... dat proefritje had ik ook wel even willen maken
Re:Mitsubishi Lancer Evo 1 12 okt 2009 11:15 #4478
Dit is ook wel oorkappen-werk in dit ding...
Re:Mitsubishi Lancer Evo 1 12 okt 2009 11:34 #4480
Mooi toch! :D
Time to create page: 0.321 seconds
