Onderwerp: Norris Designs EVO short wheelbase
Norris Designs EVO short wheelbase 16 jan 2011 12:29 #18457
Simon Norris met zijn creatie.
Power: 950bhp & 700lb-ft with 9250rpm rev limit
Weight 1180Kg (Dry)
Top speed: 215mph + (201.43mph so far )
Best 0-60mph = 2.4 sec
Best 0-100mph = 4.3 sec
Best 0-150mph = 8.00 sec
¼ mile in 9.26 sec @160.09mph on 17" Nitto 555R tyres.
Best 30-130mph = 5.06 sec
(All times recorded at Santa Pod drag strip )
Engine
ND 2.24L long rod high deck engine mounted longitudinally, ND version 4 big valve cylinder head, ND solid profile camshafts, ND solid lifters, HKS vernier cam pulleys, GT4294R turbocharger, Single Tial 44mm external wastegate, Shearer custom exhaust manifold, ND custom 5” turbo inlt pipe, 1100hp K&N air filter, ND modified DI inlet manifold, Audi RS6 DBW throttle body, ND 9 litre high volume sump, ND accusump system (motec controlled), ND custom breather system, 3.5” silenced side exit exhaust system or 4” straight through side exit exhaust system.
Cooling
ND aluminium high volume custom radiator, twin 11” fans kit, ND pressurised header tank water system with Statnt 1.5 bar cap, Ralliart thermostat, ND 1260Hp rated intercooler, ND custom 3.5” intercooler pipework, ND 25 row oil cooler kit.
Fuelling
4 x std 560cc injectors, 4x 1200cc ND injectors, SARD dash 8 large fuel regulator, DI 8 injector fuel rail, ND custom aluminium low level fuel tank, twin bosch 044 in tank fuel pumps, pre and post filters, Twin dash 8 fuel feed lines with single Dash 8 return.
Electronics
ND 5 Bar map sensor, Motec M800 bold box, ND full CDi system with coil on plug top plate, ND custom engine and full chassis loom, Armtech battery isolater system, Electronic fire extinguisher system, small race battery, Motec shift light module.
Transmission
Holinger RD6-S 6 speed sequential transmission, Sfi approved thick wall custom drag bellhousing, ND weighted gear shift knob, ND triple plate clutch, Holinger digital gear indicator, Fully selectable split 4WD system, Skyline GTR transfer box, Skyline GTR modified front diff unit, Skyline GTR rear diff unit, Carbonetic carbon front and rear 1.5 way diffs, Custom driveshafts all round, custom front prop, custom rear prop, ND big rear wheel bearing modification.
Suspension/Chassis
AST 3 way suspension system, ND custom front anti roll bar and arms, ND custom lower front suspension subframe to facilitate longitudinal engine position, Custom bulkhead mounted further back, Custom transmission tunnel with removable aluminium section for easy access, Cusco rear anti roll bar, ND custom 2.2 turns lock to lock lightweight steering rack, DC electronics electric power steering system, polybushes throughout, Hyper Zero 9.5” x 18” wheels (Dry), 285/35/18 Toyo R888 tyres (Dry), Volk CE28-N 9.5” x 18” wheels (wet), 265/35/18 Cut Toyo R888 tyres (Wet), Full vehicle air jack lifting system.
Braking
Brembo 8 pot metal matrix front callipers, 343mm Alcon front discs and bells, PF01 front brake pads, Brembo 8 pot metal matrix rear callipers, 325mm custom rear brake discs and bells, DS4000 rear brake pads, Tilton bulkhead mounted race pedal box, Billet hydraulic handbrake, Dash 4 brake lines, Castrol SRF race fluid, electronic line lock (steering wheel operated), Tilton brake bias valve.
Styling
Unique 2dr short wheel base shell (10” shorter), 3” roof chop, Tubbed front and rear arches for wheel clearance, Load bearing T45 full roll cage, Voltex Cyber Evo front bumper, full carbon undertray, canards and oil cooler guide, E9 MR front “black” lights, Carbon wide front wings, clear side repeaters, custom carbon bonnet with bulge for engine clearance, ND custom shortened C west side skirts, Carbon wing mirrors, ND custom carbon roof skin, wide steel rear arches, Carbon bootlid, Voltex Cyber Evo rear high level GT spoiler, ND custom rear diffuser integrated into std E9 rear bumper, Drag Simpson parachute and mounting, Kawasaki three stage pearl Green paint scheme, lexan side and rear windows, custom glass front windscreen, ND single wiper conversion.
Interior
ND custom dashboard, HKS 2.5 bar Boost gauge, HKS oil pressure gauge, 4WD pressure gauge, Stack race dash, Recaro Profi SP-A carbon kevlar seats, Sabelt HANS ready 5 point harness’s, ND custom carbon door cards, ND custom carbon fuel tank cover, Carbon ¾ panels, carbon boot floor panels, carbon boot side panels, Race steering wheel.
Re: Norris Designs EVO short wheelbase 16 jan 2011 19:01 #18460
kent er iemand nog een mooier aan gepaste auto als deze?????
Re: Norris Designs EVO short wheelbase 16 jan 2011 19:24 #18461
voor 100.000 pond wil ik ook wel wat leuks bouwen :P :P
Re: Norris Designs EVO short wheelbase 16 jan 2011 22:23 #18466
Jij bent al een aardig eindje opweg, struikie...... :P
Re: Norris Designs EVO short wheelbase 17 jan 2011 08:32 #18467
grrrrrrrrrrrrrrr :angry:
Re: Norris Designs EVO short wheelbase 17 jan 2011 10:07 #18469
Nog even de website; www.norrisdesigns.com/
Re: Norris Designs EVO short wheelbase 17 jan 2011 14:07 #18472
dan he je niet zoveel meer over om er nog echt iets bijzonders van te maken :P :P
Time to create page: 0.989 seconds
