Onderwerp: 1500WHP GALLARDO
1500WHP GALLARDO 20 juni 2010 21:46 #14172
- Custom twin billet 67mm Precision Turbochargers
- Mobil 1 15W50 Motor Oil
- TiAL billet wastegates and billet blow off valves
- Custom fabricated stainless steel exhaust using aircraft quality metal
- Ultra lightweight stainless steel mufflers
- Custom fabricated stainless steel air induction using aircraft quality metal
- Custom Air/Water intercooler system with high flow water pump
- Custom ice water reservoir
- High flow intercooler water heat exchanger
- Crankcase ventilation system
- K&N air filters
- Show quality polishing on turbo compressor, intercooler and charge piping.
- Custom heat shielding and high quality heat wrap
- Exhaust Finish Options:high temp heat coating or polished mirror finish
- High quality silicone hose
- High pressure T-bolt clamps for intake pressure tubes
- High quality V-band clamps for exhaust connections
- Full blue print and balanced race short block
- Carrillo billet steel connecting rods
- CP custom reverse dish aluminum race pistons
- CP spiral locks
- CP .180+ wall wrist pins
- CP oil rail support
- Custom steel cylinder sleeves
- Main bearings
- Rod bearings
- Total seal TNT file fit rings
- Stage 3 Race heads
- L-19 head studs
Re: 1500WHP GALLARDO 21 juni 2010 07:22 #14182
doemijdiemaar
Jammer van de pukkel op z'n reet.....
Re: 1500WHP GALLARDO 21 juni 2010 07:58 #14184
Die is nodig om af te remmen als hij de 400 km/u haalt...
Re: 1500WHP GALLARDO 21 juni 2010 08:00 #14185
Alleen jammer dat je bij elk verkeerslicht dat ding weer moet opvouwen...
Re: 1500WHP GALLARDO 21 juni 2010 08:42 #14187
hahahaha, daarom moet hij altijd zijn vriendin meenemen !
Re: 1500WHP GALLARDO 22 juni 2010 07:57 #14207
wwwaaahh!! ha! ha! ha! prachtig!!
Time to create page: 0.780 seconds
