Onderwerp: Extreme VW Passat
Extreme VW Passat 03 mrt 2010 12:57 #10486
Engine:
SPA 60-48 GT30R turbo DTR Ported Polished head, DTR Tubular style welded 4-1 turbo manifold w/ DEI wrap, DTR 4-inch custom stainless steel polished intake pipe, DTR Polished aluminum intake manifold, DTR Polished stainless steel intercooler piping, DTR 3-inch stainless steel V-band side exit exhaust w/ twin tips, DTR Polished stainless steel breather catch & power steering tank, TiAL 44-mm wastegate, Bosch 800cc injectors, ATP polished fuel rail, Aeromotive 700 inline fuel pump, S-MAX adjustable FPR, S-MAX SW300 BOV, S-MAX intercooler, S-MAX vacuum manifold, DEI Cry Intercooler sprayer & fuel cooler, VF engineering engine mounts, Samco silicone hoses, Worth Zebra heavy duty clamps, Neuspeed power pulleys, Polished OBD1 VR6 Throttle body, 034 Stage 2c with wide band EGO sensor, 6 SPEED w/ Quaife LSD South-bend stage 3 clutch
Exterior:
DTR Metal Widebody, DTR stretched metal sideskirts, Zender Racer R front and rear bumpers (modified), VIS carbon fibre hood and trunk, APR carbon fibre: GT200 wing, front splitter, GT3 mirrors, FK angel-eye projectors, Blue Lagoon Metallic by Custom Collision, Graphics by Balance Point Graphics
Wheels/Tires/Brakes:
Forgeline SP3-P 19x10 front, 19x12-inch rear with Falken FK452 265/30R19 front, 315/25R19 rear tires, ECS tuning stage 5 15.1-incj 2 piece rotor w/ 6-piston Porsche calipers, ECS tuning 12.1-inch rear brakes w/ 4-piston calipers
Suspension:
Easy-street sport suspension by Air Lift, Neuspeed front and rear sway bars Neuspeed upper and lower front tie bars Custom poly rear bump stops
Interior:
DTR 4-point chromoly cage, Recaro SPG seats MOMO 4-point harness belts, MOMO air metal steering wheel, shifter and e-brake handle, AEM Electronic gauges: Tru boost controller, Wideband, Voltmeter, fuel/oil pressure, Autometer programmable shift light/tachometer, Custom micro suede interior accents, ABD door sills and pedals, Pro Werks polished aluminum Co2 Bottle brackets
ICE:
Clarion DVD MAX 675VD head unit, Rockford Fosgate Power 1000 5-channel amp, Rockford Fosgate T162s 6.5 component sets front and rear, Rockford Fosgate wiring, Rockford Fosgate power T1-15 subwoofer, 3Sixty.2 sound processor Kinetic HC1800, HC600 batteries DEI Boot Mat sound-deadening
Re: Extreme VW Passat 03 mrt 2010 13:02 #10487
vind die motor en plaats van de uitlaat wel erg mooi
Re: Extreme VW Passat 03 mrt 2010 13:21 #10488
Gave bak! Al had ik zelf wel voor een ander onderstel gekozen, maar smaken verschillen gelukkig :)
Re: Extreme VW Passat 03 mrt 2010 13:26 #10489
Bora......
Re: Extreme VW Passat 03 mrt 2010 13:39 #10490
Komt van een Amerikaanse site en daar noemen ze dat ding een Jetta.
Re: Extreme VW Passat 03 mrt 2010 13:51 #10491
bora = jetta idd
maar niet een passat ;)
Re: Extreme VW Passat 03 mrt 2010 14:13 #10492
bora = jetta idd
Kan je nagaan hoe extreem ie is, omgebouwd naar bora!
Re: Extreme VW Passat 03 mrt 2010 14:55 #10493
Ik was even in de war!
bora = jetta idd
Time to create page: 0.262 seconds
