Onderwerp: Engine swaps
Engine swaps 14 mei 2009 10:16 #1029
Een auto gezien met een motor die er eigenlijk niet in hoort? Cool!
Toyota Supra met V12 van Top secret
http://forums.streetfire.net/attachment.php?attachmentid=22216&stc=1
Re:Engine swaps 14 mei 2009 15:10 #1031
Heb je meer foto's van die grijze S2 met buizenframe??
Mooi ding!
Re:Engine swaps 14 mei 2009 21:35 #1045
Ik denk dat het weer zo'n gek uit Noorwegen is ofzo, ik kan er zo snel niks van vinden
maar wie weet kom ik er iets van tegen op het net.
Re:Engine swaps 16 mei 2009 10:46 #1061
he leo van wie was die rx7 met cosworth motor?
kan em niet vinden
Re:Engine swaps 16 mei 2009 12:50 #1066
Gevonden!
Power: 440BHP & 430Lb Ft (BP Ultimate 102 Fuel)
Engine:
Cosworth YB. Stronger 4x4 200block. Special spec head porting. Forged pistons. Spec custom Re-profiled cams. Arp studded head Custom spec'd Carrillo Rods. New bearings, piston rings. 440cc injectors. Steel head gasket. Oil breather tank. Custom inlet manifold. Custom Exhaust manifold. Motorsport plenium. baffled sump & modified pickup. Uprated engine bearing set . Motorsport oil pump. Engine Castrol Edge 10W40 Sport. Turbo / Intercooler: Garrett by Honeywell GT30 Ball bearing Turbo. uprated actuator. V MOUNT !!! GTC 600x300x100 GT spec Intercooler (capable of handling up to 800BHP). intercooler pipe work. Custom tubular exhaust manifold. 60mm racing waste gate. Externally venting screamer pipe. GTC custom exhaust system with side exit. custom radiator & pressurized water system. GTC19 row oil cooler kit mounted for maximum air flow cooling properties. Reallocation plate and oil lines. Electronics /Fuelling: ecu. Updated map sensor, twin fuel pump. Boost pressure. gauge. Volt gauge. Auto Gauge 5 with Tacho meter & shift light. Oil pressure. Oil Temp. Water Temp. Exhaust temp. Hybrid boost controller. racing fuel regulator. fuel rail. fuel feed lines. fuel filters. Twin Bosch 044 fuel pumps. custom low mounted fuel tank. Swirl pot. Motorsport fuel cell. Race battery with Motorsport battery holder. Custom full wiring loom.
Exterior:
Full Kazama Auto Wide body kit. To include: front bumper, Rear bumper, Side skirts, front fenders, rear fenders. Rear FRP light weight Hatch. RE headlamp conversion. Aero catch bonnet catches front and rear. GTC Lexan windows with slide doors. HKS Kansai pulling hook modified. Single wiper conversion.
Interior:
Cobra Evolution S FIA Seat & Harnesses & Cobra side mount. Sparco GT spec steering wheel. Hydraulic hand brake. Switches: Kill switch, Fuel pump, fans, lights, starter button. Modified peddle box. Modified steering rack. Custom fabricated rear boot floor & infill panels, front floor panels . dashboard infill panels.
Drive Train / Braking:
Cossie gear box and running gear. Gear box Castrol transmission fluid. Twin plate Clutch. Mazda RX7 callipers with uprated discs and Endless CCX pads. Stainless steel brake lines. Twin master cylinders. drift gear stick. Brake Fluid Castrol. LSD. Diff Oil: Castrol.
Chassis / Wheels:
Special made just for us Weds Sports 105N?s 18x8.5 front and 18x9.5 rear in Floro yellow. With light weight racing wheel nuts. Sitting pretty on excellent Cooper Tires Zeons front 225/40ZR18 Rear 245/40ZR18
Cage:
full weld in load bearing roll cage . cage to body stiffener plates. Shell sand blasted and mass weight saving and strengthening process. Full spot weld for strengthening. Cages comes though to the bulk head.
Interior totally stripped. FIA life line electrical fire extinguisher system, air con removed, hydraulic hand brake, racing brake bias valve, boss kit, f1 style dry break fuel fitting entry with fuel breather
Re:Engine swaps 16 mei 2009 19:17 #1069
aaaaahhhh auto naar m'n hart.
een rijdend kunstwerk..........got to love it
Laast bewerkt: 16 mei 2009 19:34 Door Leander.
Re:Engine swaps 16 mei 2009 19:57 #1070
Deze RX7 ken je ook wel, die ene met een 1JZ motor van een oud model Supra.
Mooie site over engine swaps en dan voornamelijk met Supra motoren;
www.2jzswap.com/vbulletin/forumdisplay.php?f=52
Laast bewerkt: 16 mei 2009 19:58 Door Leander.
Re:Engine swaps 17 mei 2009 12:13 #1078
super gaaf!!
dit is echt een onderwerp waar me hart sneller van gaat kloppen.
o.k volgende..... voor een aantal hier een bekende.
ook als je wel eens op de samco site hebt gekeken naar de kleuren van de slangen.
zie je de mogelijkheden op deze motor veranderen.
www.samcosport.com/uk/colours.asp
de yaris mr2 turbo middenmotor van het in mijn ogen beste autoblad "redline"
de link
www.passionford.com/forum/restorations-r...s-were-building.html
vooral de laatste foto is mooi.....de midden motor.
de auto vind ik nog niet eens echt mooi, maar het reseltaat wel.
Bijlagen:
Laast bewerkt: 17 mei 2009 12:34 Door Maurice.
Re:Engine swaps 17 mei 2009 12:35 #1079
Re:Engine swaps 17 mei 2009 12:53 #1081
bedankt leo! ik kreeg het al niet voor elkaar
Re:Engine swaps 17 mei 2009 13:11 #1085
Dat leg ik nog wel een keer uit hoe dat moet.
Time to create page: 0.502 seconds
