Re: struikie - B7 Avant 2.0TDI 16V 29 aug 2012 23:16 #25407
nice
Re: struikie - B7 Avant 2.0TDI 16V 30 aug 2012 13:08 #25420
Re: struikie - B7 Avant 2.0TDI 16V 30 aug 2012 13:59 #25421
Mooi pijp werk!!!
Re: struikie - B7 Avant 2.0TDI 16V 30 aug 2012 14:33 #25423
Fred schreef :
Mooi pijp werk!!!
+1
xp windows wallpapers 30 aug 2012 14:54 #25424
  • ToicleloN
  • ToicleloN's Avatar
Windows 7 themes are some in the most striking themes. It has grow to be a incredibly hot choice for all those people who are utilizing the working technique likewise as individuals, who're still pleased with their XP and windows wallpapers free Functioning Methods. But contrarily, Windows seven themes are not appropriate with XP or Vista.
How to get it labored on other variations of running program? Scroll right down to receive the tweaks which might enable you to give a Windows seven look towards your Windows Vista and Windows XP enabled computer systems.
Put in 7-Zip Windows seven themes working with ".themepack" extension.
To extract information from the zipped Windows seven theme folder, set up absolutely free 7-zip utility. This can extract your information into a new folder.
The many Vista people that are running Aero, a ambigu just click around the freshly developed concept folder would let you alter your windows borders in one in the downloaded theme outlook.
Individuals consumers, who will be wanting to employ Windows seven theme on XP enabled device, can it accomplished by significantly clicking 'set as desktop track record.'
There is another gentle tool, which aids in establishing windows themes on XP. This is called "wallpaper shifter app." This application picks random wallpapers from picked directory and sets it because the lively Windows wallpaper.
If you need to include concept sound and Icons, it is extremely very easy to do, while you only ought to duplicate the audio information (these are normally in.wav format) towards the default media folder.
To include any windows seven concept icons with your Windows Vista device, you must appropriate simply click at anyplace to the desktop and then opt for 'personalize.' It'll be adopted by clicking on 'change desktop icons.' Now chose the icon, which you wish to.
To change desktop icon in XP enabled device, like Windows Vista, you need to appropriate just click everywhere on Desktop. Now opt for 'properties'. This would be adopted by choice of 'Change Icon' tab then browsing of latest icons.
To alter your Visa or XP screensavers or cursors' appearance into Windows 7, you are able to duplicate the screensaver information through the downloaded Windows 7 concept pack and replicate into windows procedure folder. You may alter them by taking a tour to regulate panel.
Appreciate Windows 7 attributes on the Windows Vista and Windows XP system... Your entire treatment is bit time-taking but look is price the compensated time.
Re: struikie - B7 Avant 2.0TDI 16V 30 aug 2012 16:25 #25427
Re: struikie - B7 Avant 2.0TDI 16V 30 aug 2012 23:08 #25432
Mooi stukje maatwerk, top !
Maarruh die bumper daar zo op de werkvloer, komt dat goed. :whistle:
Dat deed ik ook een keer, bij de 8L, direct de lak eraf. :S
Die kan toch gewoon achterin de Avant liggen.
Re: struikie - B7 Avant 2.0TDI 16V 31 aug 2012 23:06 #25437
Johan heeft vandaag de Audi afgesteld en wat ik tot nu toe heb gehoord is 254pk en bijna 500Nm...
op dat moment wilde Johan nog wat meer brandstof onderin geven ;)
Re: struikie - B7 Avant 2.0TDI 16V 31 aug 2012 23:40 #25438
Dat zijn serieuse cijfertjes, JW.
Kan het morgen dus nog niet uitproberen ;)
Re: struikie - B7 Avant 2.0TDI 16V 31 aug 2012 23:41 #25439
helaas Herold... ga hem dinsdag avond ophalen...
zo kan Johan er nog even meer rijden om te zien hoe alles gaat...
Re: struikie - B7 Avant 2.0TDI 16V 02 sept 2012 21:30 #25449
Miste hem al het weekend, maar ondanks dat waren het 2 gezellige dagen.
Re: struikie - B7 Avant 2.0TDI 16V 02 sept 2012 21:39 #25450
gelukkig hadden we nog een mooie A3 om naar te kijken ;)
Re: struikie - B7 Avant 2.0TDI 16V 02 sept 2012 23:09 #25452
Van wie was die dan? :roll:
Re: struikie - B7 Avant 2.0TDI 16V 03 sept 2012 00:22 #25453
>van mij<?
Re: struikie - B7 Avant 2.0TDI 16V 03 sept 2012 20:25 #25455
morgen de B7 weer ophalen !!!
best wel zin in :P
Re: struikie - B7 Avant 2.0TDI 16V 04 sept 2012 17:59 #25462
Waarom zou je daar nou weer zin in hebben?? :P
En??
Re: struikie - B7 Avant 2.0TDI 16V 04 sept 2012 20:07 #25463
En ?
Re: struikie - B7 Avant 2.0TDI 16V 04 sept 2012 22:47 #25464
wat is het toch een fijne auto zeg... bizar stil geworden...
het verwijderen van de balansassen geeft idd. wel wat meer trillingen die doorkomen in de auto...
maar het is zeker niet overdreven of storend...
het stotteren is veel en veel beter, maar ik betwijfel of het ooit wel 100% weg te halen is...
eerst was het echt irritant, nu alleen nog maar een beetje merkbaar door een zeikerd als ik ;)
de grotere midden demper doet ook erg goed zijn werk, het is heerlijk stil in de auto,
ook met vol gas optrekken !
Re: struikie - B7 Avant 2.0TDI 16V 04 sept 2012 23:16 #25465
Mooi dat het resultaat er is, nog één grote stap en je bent klaar. :blush:
Binnenkort maar eens even zelf horen en voelen.
propecia online 887 8370 04 sept 2012 23:59 #25466
  • innoffexcic
  • innoffexcic's Avatar
buy generic propecia - <a href=http://buypropeciaonlineone.com/#awww.turbotuners.nl>buy propecia</a> , buypropeciaonlineone.com/#swww.turbotuners.nl buy propecia
Time to create page: 0.915 seconds
